ALOT of spark knock
Old May 20, 2007 | 01:50 PM
86whitetpi's Avatar
Car: 1986 Trans Am WS6
Engine: 305 T.P.I
Transmission: 700 R4
ALOT of spark knock
I just bought this 86 Trans Am with a 305 TPI and 700r4. The problem is it spark knocks like crazy when under hard excelleration. I put 91 octane gas in it, new cap, rotor, plugs, K&N filter and pulled the catalytic convertor off and put a series 80 Flowmaster muffler on it. The car starts and idles fine. Please help.
Old May 20, 2007 | 02:01 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
Re: ALOT of spark knock
what is the ignition timing at idle? at 5000rpm? has this motor ever been apart?
what is the compression ratio? what is the park plug heat range? Are you sure its a spark knock not broken pistons slapping around?
Old May 20, 2007 | 02:13 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I'd start by checking your timing with a gun.
Old May 20, 2007 | 06:13 PM
86whitetpi's Avatar
Engine: 305 T.P.I
The motor is a GM crate motor with less than 50,000km, It was running good then it started pinging loud after I put a mechanical temp gage in it. The factory gage would not move so I replaced the sensor and still nothing.I left the sensor plugged in and tie wrapped it to the fuel lines and grounded it. Could it be the knock sensor or the spark control module ? I am new to any GM product, I was a mustang guy for 16 yrs.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
efiguy
Sep 27, 2015 01:30 PM
