AC control smoking HALP
Old May 22, 2007 | 10:18 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
http://moderndaymuscle.com/inc/sdetail/747
With the A/C switch off,
it was giving me a slight white smoke, and as I turn the A/C on, the smoke
increase and smells so bad, and ofcourse I had to turn them off and stuff.
It doesn't smoke anymore since I unplugged that brown(tan?) wire going to the control.
Could this be my temp. sensor thing? or the control itself?
any ideas before I possibly waste 100$ on a new control?
thanks!
Old May 23, 2007 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: AC control smoking HALP
Originally Posted by sogabe
[url]It doesn't smoke anymore since I unplugged that brown(tan?) wire going to the control.
The following from Sofakingdom:
Remove the AC control head. Observe the wiring. You'll find a harness with about 4 or 5 wires in it that goes off one way (toward the blower resistors and the AC low-pressure switch, actually), and a single brown wire that goes off another way all by itself. That brown wire is the power source for the entire HVAC system. Follow it about 12-15" up into the dash. You'll come to a connector. Attempt to unplug it. You'll almost certainly find that it has degenerated into a pile of ashes. Replace it, even if it "looks" good to you, with a set of BIG THICK HEAVY yellow insulated slide terminals; not the ordinary little weenie thin ones, but rather, BIG THICK HEAVY. Odds are, that will fix it.
JamesC
Old May 24, 2007 | 04:21 AM
sogabe's Avatar
Engine: 3.1L
thanks James,
although I have another question though.
tracing that wire for 12-15", will that require the whole dash to come out or something? seems pretty long to me.
I'll try and take a look and try to find a pile of ash. Thanks!!
Old May 24, 2007 | 05:19 AM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
You shouldn't have to remove the dash.. just the bottom area under the driver's side. Since that is the way the wire goes.
Old May 24, 2007 | 04:17 PM
sogabe's Avatar
Engine: 3.1L
hey thanks!
I'll look into that sometime tomorrow then
69GTOby
Apr 18, 2016 02:34 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
Accerrito22
Sep 5, 2015 09:34 PM
