Setting total timming on 89 TPI 350. Possible?
Old May 23, 2007 | 08:20 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
Me car is a 89 350 tpi lb9 runns great now that i have ne new injectors, but it seems to lag in power it dosent pull like i know it can and has before even with fried injectors.So i bought some timing tape but can i set total timming on a TPI car where is electronicly controlled. or what what should i do to get some power going,
Old May 23, 2007 | 08:28 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Setting total timming on 89 TPI 350. Possible?
to properly make changes to the timing, you need to do it in the chip.
Old May 24, 2007 | 09:38 AM
Car: 89 Iroc
Engine: 5.7 TPI
Thats what i was thinking. Any ideas on what i can do to figure out why im not pulling like i should... i have a video of this car i have now runing a 13.99 with one of the previous owners and it was in crappy conditions then all rigged up and stuff now its fixed with new boseh injecotrs and it dosent seem to pull like it did before.
Old May 24, 2007 | 03:28 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
you have to disconnect the wire that controls the distributor first. i don't remember what color it is, but brown comes to mind.
Old May 24, 2007 | 03:44 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
you can mess with base timing which adds to the total timing by turning the distributor around.
need to disconnect the EST wire before you make adjustments tho. base timing for stock cars is 6 degrees advanced. some ppl like to try 8-10 degrees advanced. i have mine set at 8 now but have tried 10 and reallly didnt feel much difference. i'd have to track test it.
Old May 25, 2007 | 11:27 PM
Car: 89 Iroc
Engine: 5.7 TPI
Thanks alot for the replays, yes, im deffinatly going to change the base timming. it at 6 right now and i think i had it on 8 or 10 before i did the injector swap. my car just feels like it lossses all of its torq after 1st gear. i mean its still going but it dosent have the G-force ive felt from it before. any other tips will help also timming or non timming related thanks
Old May 26, 2007 | 12:52 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thats how TPI cars work... basically stock cars will pull hard in first cuz the gearing is soo deep. after that it drops off and the TPI cars dont have the hp and upper rpm torque needed to pull thru those gears.
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Grant2k
Jul 10, 2018 04:01 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
