which ones should i get???
Old May 23, 2007 | 11:00 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok i need some locking nuts for my roller rockers. they are full roller alum. rockers they came without lock nuts. looked on summit and they have different heights. does the height matter? here is the link---
http://store.summitracing.com/egnsea...=KeywordSearch
Old May 24, 2007 | 03:54 AM
Pat Hall's Avatar
Re: which ones should i get???
Looks like most of them for full roller rockers are a bit over 1" tall. The ones shorter than that look like they're for the stamped steel style that just have a roller tip. The only odd one is the Comp Cams set that are 1.3". I would say any of the ones that are 1" tall should work just fine. Probably go with the .550 outside diameter, as that seems to be the most common too.
Old May 24, 2007 | 04:19 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i would go ARP.. but thats just me.. i have never broken anything ARP..
