help me get my SD lb9 to start
Old May 27, 2007 | 12:43 AM
92purplehaze's Avatar
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
I just bought an lb9 iroc with the intake off. The previous owner said it was blowing steam so he took it apart to clean it up and fix it. I putback together today and dropped the distributor back in. I hear the fuel pump turn on and it turns over but it wont fire. It will almost start (just a slight stumble) in about 3-4 second intervals. Theres also a strong gas smell after I crank it. Could I have put the distributor on wrong (I went by the marks the previous owner put on there and it looks identical to my l98) or is there a trick to getting a TPI to start after its been taken apart? I'm thinking its more of an ignition problem than a fuel because of the gas smell. Any help is appreciated...
Old May 27, 2007 | 11:31 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: help me get my SD lb9 to start
Do a search for how to put the distributor in time. It may be 108' out or one tooth off.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
happyhapka
Aug 15, 2015 04:42 PM
kyleb24
Aug 15, 2015 08:24 AM
