Guess this part...
Old Jun 6, 2007 | 11:59 PM
Overcast32's Avatar
Engine: 305 TPI - LB9
Transmission: 700R
Guess this part...
I could take a pic if needed - but I'm curious what a certain part is called... I already pulled it from the car, so if I did take a picture, it would have to be two of them - just hoping maybe someone knows off the top of their head...
1988 Trans Am - 305 TPI
It's a 3 way vacuum connector - one connection goes into the Throttle Body, next line to the Cruise Control Servo and the other connects to one of those plastic vacuum lines and runs into the firewall I do believe.
It's obviously some portion of the control for the Cruise, but I haven't a clue what it's called.
I found it was 'repaired' with a bit of electrical tape, when I pulled off the tape, it just fell apart, lol. Although, the car started to idle nice and smooth when I plugged up the vacuum leak.
Old Jun 7, 2007 | 12:39 AM
Stephen's Avatar
Car: 87 GTA
Re: Guess this part...
Sounds like the heater control valve, off the top of my head. Could that be it?
Old Jun 7, 2007 | 02:31 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
i believe your talking about the vacuum check valve.
does it look like this?
http://www.midwayautosupply.com/pc-1...lve-47150.aspx
Old Jun 7, 2007 | 07:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Yeah. Sounds like the check valve. I believe GM calls it the Cruise control/hvac check valve. I had to get one before. Wouldn't hold vacuum anymore.
Old Jun 7, 2007 | 08:17 AM
Overcast32's Avatar
Transmission: 700R
Yep!! Thanks a ton
Yeah - it pretty much just fell apart once I took the tape off, couldn't even really get the hoses off the remainder of it without it just falling apart.
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
