Need help figuring out my comp ratio..
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
I currently have 882 casting heads with 9.6 -1 cr.. thats with 76cc heads, im getting patriot freedom series heads with 64cc chambers, can anyone tell me what my comp ratio will be? thanks
Re: Need help figuring out my comp ratio..
Without knowing all that, you also would have no way of knowing what your CR is now. Looking up in the catalog and seeing the pistons are sold as "9.6:1" or whatever, is NOWHERE NEAR accurate enough, due to all the production, machining, assembly, and parts selection variations that are possible.
Not too sure on all that stuff... Just going off what I was told when I bought the car.. its all stock except for being bored .030, gonna pull the old heads this weekend.. could you give me a well educated guess?
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I doubt you have 9.6:1 with 76cc heads. Once you pull off the old heads you can measure the deck height, measure the piston dish size, and then we can help you out.
