carb swap ?
Old Jun 28, 2007 | 08:58 PM
babybear82lilj's Avatar
Car: 87' T/A, 83' caprice classic & Zx7R
Engine: TPI 5.7 , 71'350 4blt main
Transmission: 700r4 , 700r4,6speed Stacked
Axle/Gears: 3:42LSD , 2:55open 15f,43r chain
carb swap ?
i have a q jet carb on it know it is junk so i bought a eldelbrook 600cfm i want and need to intsall this but i just had a thought so i figured i would ask before i tear down and then cant figure out why it wont start after i install the edel. The q jet has an electric plug on the front drivers side of it, the edel doesnt will this cause any ignition prob if i disconect and cut the wire off to clean up with the instal of the other carb. my HEI is not a vacume advance it is electronic if i remove the conection on the q jet will my car still run. and is 600cfm too much carb for a stock 5.0 if that is what my motor is.
Old Jun 28, 2007 | 09:08 PM
Re: carb swap ?
the guy i bought it from said the guy he bought it from said the motor had been swaped to a 350 but i dnt know for sure does nebody know n e websites i can trace the vin # on my motor.
Old Jun 28, 2007 | 09:55 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: carb swap ?
okay first the carb swap... yes i think you will have problems but they can be solved by getting a new dist. that is vaccum/mech. advanced
then for the ever incesent question is it a 350... well www.mortec.com
has pretty much all of the SBC casting numbers
the casting number it self is located on the driverside you have to look between the engine and the fire wall there is a ledge on the block about 1 inch wide that will have the number on it might need some engine degreaser and a flashlight to see it even then it will be very hard to make out... requires some creative guessing
Old Jun 28, 2007 | 10:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb swap ?
The Quadrajet is a better carb than that Edelbrock.
As above, you'll need to replace the distributor. The car will "run", but it won't be happy.
Old Jun 29, 2007 | 02:02 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: carb swap ?
youre getting yourself into a kinf od a mess if you dont know what the ESt/CCC system is and how it works
if you put the edel carb on youll have to get a non CCC dizzy and remove the EST/CCC system harness and the ECM too
it is stand alone all on the pass side of the car
its pretty straightforward and simple for someone like me only takes about an hour to totally convert over to non ECM but ive done it a million times
but i dunno what your abilities are though
the edelbrock will use alot more fuel than the Q jet did and is generically tuned and jetted out of the box and will require some modifications to make it work in the car including choke wiring and accelerator linkage work and so on
Qjet is indeed the best tuned and efficient,
is is a larger CFM carb than the edel but is jetted alot more efficiently, more air and less fuel
good luck
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
cstrobel65
Aug 15, 2015 10:19 AM
