113 heads for $350?
Old Jul 2, 2007 | 08:54 AM
Kurt04's Avatar
113 heads for $350?
He says:
I have a set of Aluminum heads off a 90 vette. #113 castings. Just took some pics real quick. I just noticed when I pulled them out of my car that the #7 piston tapped the head as you can see in one pic. It's still fine, I would bolt these on another motor as they sit.
I have been able to look at the pics yet, but I will post them up when I do.
Should I ****** these? I honestly not sure where I am going with this current engine build but I have seen these go for upwards of $500.
Old Jul 2, 2007 | 09:06 AM
Re: 113 heads for $350?
That's about the going price for a pair of just yerbasic used ones.
$500 would be too much for just used untouched stock cores; but maybe not too bad for a set that already had some of the work they need done to them, like better springs, better valves, port work, etc.
As far as "should you ****** them", that depends on your goals and all that. They're easy to beat with aftermarket heads.
Old Jul 2, 2007 | 09:48 AM
Kurt04's Avatar
Yeah, they might be sold already. I also checked out some comparable Alum heads, most go for $500ish range. So unless they don't sell and he comes down on the price, I doubt I will get them.
lt500r55
Sep 1, 2021 01:30 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
NinjaNife
Aug 23, 2015 11:49 AM
