torque specs on rod and mains
Old Jul 4, 2007 | 07:08 PM
MartinD's Avatar
i need the bolt torque specs on the rod and mains on a 92 chevy 350 truck engine.4 bolt main.(cant find my book)
Old Jul 4, 2007 | 07:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: torque specs on rod and mains
Depends on the bolts you're using.
Factory spec is something like 40ftlbs on the rods, and 65ftlbs on the mains.
Old Jul 4, 2007 | 07:47 PM
MartinD's Avatar
It is the stock bolts
Old Jul 4, 2007 | 08:11 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
45 for the rods
75 for the inner mains
65 for the outer mains
Old Jul 5, 2007 | 04:31 AM
Pat Hall's Avatar
Apeiron's specs are right on the money.
Old Jul 5, 2007 | 07:11 PM
Damon's Avatar
Just remember to use the proper lube on the fasteners before torqueing them down. Without the proper lube on them the torque readings will not provide the proper stretch on the bots (the TRUE desired end result of a proper torque setting).
Usually it's engine oil for parts like mains and rod bolts (at least factory ones).
The few times I've double-checked using a stretch gague on the rod bolts I've found they want more than 40 ft/lbs to achieve the desired amount of stretch (even with proper lubrication). That's why mine usually end up closer to 50-55. But I use ARP rod bolts in almost everything I build, which are NOT the same as stock bolts.
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
john204481
Sep 7, 2015 03:22 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
