What's the torque value?
Old Jul 10, 2007 | 12:23 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey Ya'll - What value should I torque the screw in rocker studs ( with guide plates ) to in my aluminum heads ? Thanks for your info in advance !!
" Ain't that a kick in the head "
Frank Sinatra - 1959
Old Jul 10, 2007 | 02:26 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: What's the torque value?
T-rick'srod,
About 50lbs should do the trick on those aluminums. Don't forget the sealer.
Rabi C.
http://torquespecs.tripod.com/hi_po_chev.htm
http://www.hotrodshack.com/torque_settings.htm
http://www.boxwrench.net/specs/chevy_sb.htm
Old Jul 10, 2007 | 07:26 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Only need the sealer if the studs go into water or an intake port. Lots of aftermarket heads do, stock GM stuff doesn't.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
