Has anyone used retrofit roller lifters? Same pushrod length as L98?
Old Jul 23, 2007 | 05:14 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have a set of Speed Pro retrofit roller lifters (pivot link style) in the mail off ebay. I am finally going to convert my 327 to use the custom roller cam I have.
Will the retrofit roller lifters use the same length pushrod that a stock 87+ roller motor (like a TPI L98, etc) would use, or will I have to measure and get custom pushrods?
Thanks!
Steve
Old Jul 23, 2007 | 05:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Has anyone used retrofit roller lifters? Same pushrod length as L98?
No, they're not the same.
Old Jul 23, 2007 | 05:19 PM
Car: 2000 BMW M5
Thanks for your very fast reply. I found that the manufacturer specs 7.29, which I'll order up. My block is undecked and I'm using normal 0.022 head gaskets.
Old Jul 23, 2007 | 05:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'd be better to wait, measure, and then order the correct ones which may or may not turn out to be that length.
FormulasOnly
Jul 23, 2018 08:47 AM
skinny z
Oct 5, 2015 06:23 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
