My car won't run right...
Old Jul 29, 2007 | 09:31 AM
88tpituner's Avatar
I have a 1988 T/A 5.0 TPI. I had to take it off the road cause it did not stay running. Firstly, It takes 10-15 seconds of cranking to start the vehicle. It has been like that since i have owned it. But now my problem is everytime i take a turn the engine will cut out, sometimes even going straight. It does not bog down. It does not even feel like it is stalling. It will just cut out. Before i took the car off the road i tested the car by taking the turns differently but to no prevail it is not my driving. I have already replaced the TPS but i needed to replace it anyway. I was told that it could possibly be the inertia switch but i am not positive. Any response is a good response thank you for reading please e mail me your suggestions @ Gtatpi112305@yahoo.com
Old Jul 30, 2007 | 02:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Check fuel pressure. You could very well have no pressure at initial ignition turn-on, which could be a relay problem or a pump problem.
The cutting out thing could also be fuel pressure related. Or, could be a whole host of other possibilities.
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
kyle5647
Aug 7, 2015 03:08 PM
