PCV to manifold?
Old Aug 3, 2007 | 07:23 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
PCV to manifold?
can i route the PCV line from the PVC valve right to the manifold?
Old Aug 3, 2007 | 09:10 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: PCV to manifold?
Originally Posted by //<86TA>\\
can i route the PCV line from the PCV valve right to the manifold?
Yes. If you hook it to a TB or Carb the end result is the same. You still get positive Crankcase Ventilation.
Now, if you were to use vacuum advance... which I have recently discovered with the help of others, uses different types of vacuum sources. PCV needs to be vented back to the intake thats all.
Pac J
May 17, 2020 10:44 AM
sailtexas186548
Feb 17, 2017 03:07 PM
Chas91Z28
Oct 22, 2015 10:12 AM
NZKnight
Oct 15, 2015 02:47 PM
