Air Conditioning Smells Like Gas
Old Aug 9, 2007 | 01:42 PM
wgripp's Avatar
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Once in a while when I'm running my A/C, I smell what I think is gasoline. This is odd, since the car doesn't appear to leak any fluids. How can I fix this?
Thanks!
Bill
Old Aug 9, 2007 | 03:41 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Air Conditioning Smells Like Gas
i do not mean to hi-jack your thread but i to have a chemical type smell from my a/c as well . i aslo would like to get rid of it . can anyone help us both out ?
Old Aug 10, 2007 | 11:50 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
I smell it too in my TPI camaro, its almost like an exhaust smell in my car.
Old Aug 11, 2007 | 12:16 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
how about exhaust leaks....
Old Aug 11, 2007 | 06:08 AM
UNCLE TOM's Avatar
well i studied the system , realized the a/c draws in outside air from wiper area . since i had removed the rear hood seal i was pulling in hot eng. air/fumes . glad i had not thrown the seal away as many have done . re-installed seal , problem is gone . worked for me , hope it works you all .
Vintageracer
Jan 10, 2020 05:33 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
BurlyChev
Aug 16, 2015 09:08 PM
jackhammer
Aug 15, 2015 10:04 PM
