Car Sitting Too Long?
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
I have had a habit of letting my car sit for months on end between starting it (winters, been away from home, etc.)
I don't think this will be an issue anymore, since I'm getting a storage unit near my home for the vehicle. However, the car needed to be jump started last week (I guess the battery died from sitting too long.) I never had this problem before.
Is there anything else that the time could have done to my car? Any precautionary maintenance I should perfom before I start driving it again on a regular basis?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Car Sitting Too Long?
Adding some fuel stabilizer before you put it away is a good idea.
Car: 87 Trans Am, 89 RX7
Engine: 350tpi,350carb
Transmission: T-5,t56
Axle/Gears: 3.42 Posi,4.11 posi
And if you're gonna be away for so long between starts disconecting the battery terminals so it doesn't drain the battery would be good too.
Thanks for the tips guys. Is there anything you recommend I do before I start driving the car again on a regular basis?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Check the water in the battery - if its OK, charge it for a day or two on trickle charge and it should be OK if the battery isn't toast. DON'T use the alternator to charge the battery, or you may fry it.
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
I usually park my GTA in September/October and don't put it back in service again until June/July... (Last year, I only drove it for the month of July).
Other than removing the battery and putting a trickle charger on it for a day or so every few months, I don't do anything special to the car. I've had it for 15 years. Just to be different, last year I jacked the car up and put it on axle stands for the winter.
15, 3rd, car, generation, letting, long, maintenance, month, rx7, sit, sitting, start, time, transmission, years
