timing question
Car: '84 Z28, '86 IROC
Engine: 305, 406
Transmission: T5, Super T10
Axle/Gears: 3.23, 4.10 Posi
timing question
how much timing should the esc be putting on the engine at idle?? because my 86 tpi is throwing a code 43 and the base timing is set to 6* but with esc hooked up at idle it has something like 28* of advance and when you snap the throttle it retards the timing then eventually readvances it...and the motor has a bad stumble...any ideas?
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: timing question
Did you disconnect the ESC connector? If so, that's what's throwing your code 43. If not, then you need to start diagnosing the problem.
Could be your spark module, wiring, or knock sensor.
