N00B Question
Old Aug 14, 2007 | 07:57 PM
kdxrider9262's Avatar
Car: 1987 IROC-Z Camaro
N00B Question
What is the difference between a short block and a long block? also my uncle says he has a "4 bolt" 350 he said he would give me........what is the diff between a 4 bolt and a regular 350?
Old Aug 14, 2007 | 08:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: N00B Question
A short block is just the block with crank, rods, pistons and cam I think.
A long block is a short block, but it also has the heads on it.
350's came with either 2 bolts holding the main caps on (that's the "saddle" that holds the crank in place), or 2 bolts on the front and back, and 4 bolts for the middle 3. A 4 bolt main usually came in trucks and whatnot, the theory was that it made the engine stronger. For trucks lugging heavy loads yea, but for us it's a very small detail.
Old Aug 14, 2007 | 08:04 PM
Re: N00B Question
Great thanks!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
