LT1 timing pointer
Old Aug 19, 2007 | 05:54 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
LT1 timing pointer
I am trying to fab up a timing pointer, is this correct?
So, I put the piston stop back into #1 cylinder and did the same thing. I rotated the engine clockwise until the piston hit and recorded the timing mark value on the balancer with the pointer that I fab up in the last step, the value was 245 degrees. Next I rotated the engine counterclockwise and got 114 degrees. 0 on the balancer is marked TDC, so from my last measurements I am 114 degrees counterclockwise and 115 degrees clockwise, 1 degree off.
Did I do somthing wrong I cant see, from what I think my timing mark should only be off 1 degree or so. But why am I getting 90 degrees when I use a timing light.
Now I know from my scanner that this car reads 28 degrees at idle, I just want to be sure that is where it is at since I installed the adjustable MSD optispark.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
TheExaminer
Aug 19, 2015 10:07 PM
Thirim
Aug 9, 2015 06:19 PM
z28addict8490
Aug 7, 2015 08:48 PM
