L03/LB9 Question...
Old Aug 28, 2007 | 02:16 PM
Imadude_134's Avatar
Car: 1991 Camaro RS
Engine: L98 350 TPI
Axle/Gears: ZT LSD with 3.42 - LS1 brakes
L03/LB9 Question...
I know this is probabaly a dumb question, but is there any difference (internally) between the L03 and the LB9? (stroke/bore)
Also, would using forged internals have any benefit on a n/a car?
Thanks in advance for the help.
-Tim-
Old Aug 28, 2007 | 03:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: L03/LB9 Question...
Bore and stoke is the same, cam and heads and intake (obviously) are different.
I wouldn't waste my time on forged internals unless I was going to use forced induction. All you get is a faster wearing bore and piston slap
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
no the bore and stroke on a 305 is the same
and on a N/a street engine there is no need for forged pistons or crank...
Old Aug 28, 2007 | 04:42 PM
Car: 1991 Camaro RS
Engine: L98 350 TPI
That's what I thought, I was just wanting to make sure. Thanks for the help!!
-Tim-
Galaxie500XL
Oct 1, 2015 01:05 PM
happyhapka
Aug 15, 2015 04:42 PM
blak92!
Sep 30, 2011 06:25 AM
ebmiller88
Jan 28, 2002 09:51 AM
KlayBuRn
Car Audio
Aug 30, 2001 12:52 AM
