Can GM Vortec Head/Intake Gaskets be reused?
Old Aug 29, 2007 | 06:20 AM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
I need to remove the passenger side head and put it back. (engine never started since install) I'm using the factory GM plastic/rubber (or whatever they are) Vortec gaskets. Can they be reused? I am also guessing I can reuse the GM Vortec intake gasket?
I was assembling my TPI Vortec w/SD intake and realized I needed to take one of the heads off to tap a bolt hole since the L98 heads have an extra exhaust manifold bolt.
thanks.
Old Aug 30, 2007 | 05:56 AM
Damon's Avatar
Re: Can GM Vortec Head/Intake Gaskets be reused?
Intake gaskets- yes, they are reusable, especially if the engine has little or no run time.
Head gaskets..... maybe, since you didn't run the engine. See how they look when you disassemble. If there's any tearing or lifting when you pull the head off, they're toast.
sheachopper
Jul 31, 2019 11:27 AM
Quzyle
Oct 15, 2015 03:35 PM
Jonas Earl
Sep 27, 2015 07:39 AM
monte87cortez
Sep 26, 2015 08:10 PM
WhteRbt
Sep 21, 2015 09:48 AM
