what part number for accel header spark plugs
Old Aug 30, 2007 | 04:46 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Not sure which plug is the right one for my motor, specs in sig, its a 300 hp 355 with 10.5:1 compression
check out page 159 in the new accel catalogue
http://www.accel-ignition.com/pdf/74283G.pdf
i cant figure out if the part number for the accel shorty plugs i need is 8198 or 8199 its not overly specific.
possibly theres even something slightly hotter or colder that i could use? i assume thats the difference.....
Old Aug 30, 2007 | 05:17 PM
onfire's Avatar
Car: 88 Formula 350
Engine: 5----->.7 or so they say
Transmission: seven hundred with a remainder of 4
Axle/Gears: 9 bolt 3.27
Re: what part number for accel header spark plugs
19doug90,
I am running the ac delco plug fr3ls. Its a shorty plug that runs cooler for aluminum headed engines. They are cheap and have not let me down in the 9 years I have been using them. I have tried others of course but always come back to them. Just gap them and enjoy.
Rabi C.
Old Aug 30, 2007 | 09:44 PM
mr_nopants's Avatar
Car: 1987 Camaro, RS ground effects
Engine: 305 w/ 650cfm Edelbrock
Go to O'Riellys or Autozone, or whatever your favorite parts store is and ask them I'm sure they'll be able to tell you. That's how I found out what plugs I needed to use. If they don't know what ones fit your heads the call the manufacturer of your heads or if you have stock heads run the casting number to find out what year any everything.
Good Luck
Old Aug 31, 2007 | 01:05 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Good Luck
i was hoping someone would have an idea
if you look at the catalogue in the link on the page i listed im pretty sure its 8199, its listed somewhat clearly, just woundered if anyone had a better idea
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
