anyone know what pistons are in here?
Old Sep 3, 2007 | 12:31 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
does anyone know what pistons came in this motor? or what the Piston Deck Clearance of the motor is?
http://store.summitracing.com/partde...3&autoview=sku
Old Sep 3, 2007 | 01:08 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: anyone know what pistons are in here?
They are just a stock type cast dished piston. probabily a 15cc dish volume.
The stock compression height is 1.56"
Old Sep 3, 2007 | 01:12 AM
well i am trying to figure out my cr, and using the calculators you need to know the " Piston Deck Clearance"
Old Sep 3, 2007 | 01:14 AM
F-BIRD'88's Avatar
.025" you can get a decent 9.8:1 compression ratio using a 58cc head with a thin steel shim head gasket.
Milling your 62cc head to 56cc and using the same .015" gasket will get you 10:1.
Old Sep 3, 2007 | 01:44 AM
ok thank you.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
