Need quick help
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
Need quick help
I'm currently dropping the engine in my camaro. When I pulled the old engine out a large 2.75" wide x .75" thick washer that tapers fell out from behind the engine. The old engine was a 305 w/ 1 piece rear main. The trans is a 700R4. Does anyone know what this washer/spacer was for and would I need it for a 2 piece rear main flywheel and the 700R4?
Car: 89 RS
Transmission: th350
Re: Need quick help
Cant think of anything that a washer that size can be used for in your engine bay. Maybe someone droped it and it got stuck somewhere and it workded free when you was pulling the motor.
Car: 1991 Camaro RS
Engine: 355
Re: Need quick help
I figured out that it was an exhaust donut. I guess what threw me off is that it dropped right underneath the bellhousing and it was covered in oil and grim.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Need quick help
3.8TransAM
Sep 27, 2015 08:37 PM
