carb selection question
Old Sep 6, 2007 | 08:36 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
here is my dilema i have a 383 with about 11:1 compression with 200cc/64cc 2.02/1.6" heads a .480/.480 cam with edelbrock performer rpm intake and a 1" spacer and an edelbrock 1411 carb rejettted and changed the rods to match a 1407. now is there a difference in the overall design of the two carbs besides the jets and rods? i ask because it says on the edelbrock website that you shouldnt use the 1411 with the performer rpm intake which may be why my dyno was so terrible. well any way my main question is what is a good out the box carb to put on top of my motor?
Old Sep 6, 2007 | 08:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: carb selection question
The only difference between the two is the choke, and the jetting out of the box.
Old Sep 6, 2007 | 08:47 PM
Car: 85 trans am
Engine: 383 stroker
thats what i figured on but you never really know till you ask. is it worth trying to mess with what i got or go get another carb??? i also got the one i have off ebay so who knows what the real condition is. it doesnt look bad from the outside but im not sure.
Old Sep 6, 2007 | 09:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could try to make it work. Even if you had to take it apart and clean it out, the rebuild kit isn't expensive and those are about one of the simplest carbs ever.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
