No fire to the injector, whats the problem?
Old Sep 7, 2007 | 07:36 PM
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
Hi. I have a '89 IROC-Z with 5.0 V8 TPI. There is "fire" going in and out the distributor (which was just replaced) and there is fuel pressure. There is NOT "fire" going to the injector, therefore, the car rarely cranks and when it does, it doesn't go far before the car dies. Could someone please tell me what the problem may be? Thanks!
Old Sep 7, 2007 | 10:44 PM
malkavian's Avatar
Re: No fire to the injector, whats the problem?
a buddy of mine had a problem like this although it was on a truck with a tbi. After I shot wires for about 30 mins I found a spot on the wiring harness that looked like it had been pinched two wires where about pinched in half. it was at the back of the engine and looked like they might have been caught when the transmission had been taken out. I cut out the bad spots and soldered in fresh wire and it fixed the problem. Just a idea.
They also make test lights you can plug into your injector harness and have some one crank the engine. It will flash it its getting fire.
Old Sep 7, 2007 | 10:54 PM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
How did you come to the conclusion that there is no "Fire" to the injectors? Have you checked the fuel pressure?
If the fuel pressure is good, I would say you may have a shorted injector or injectors
If fuel pressure in low, I would check for a clogged fuel filter or dying fuel pump, maybe a bad regulator.
Old Sep 8, 2007 | 08:15 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
Well, I asked my dad (who works on my car) and he says that can't be possible since this car has a standard transmission. he says that the transmission has its own housing and that there wouldn't be any wiring in the way to be pinched.
Old Sep 8, 2007 | 08:29 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
My dad is the person who has been working on my car. He's the one who told me that there was no fire to the injector. He did check the fuel pressure and he says that there IS fuel pressure. He changed out my fuel filter last week and it ran a little better until it broke down again the next day. The only problems I think it can be is either the fuel pump like you said, a bad regulator, or the computer. Thanks for your input, it may help
Old Sep 9, 2007 | 12:25 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
did your dad make sure that the pressure was at 44 psi or just that it was flowing and asumed it was good pressure. common mistake. the 44 psi is after the regulator before the injectors. the fuel pumps seem to be an issue at this age of our cars, yours could be going out.
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 21, 2015 07:20 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
