Fuel Injectors & Pump suggestions please
Old Sep 11, 2007 | 09:07 PM
Z28_1991_Camaro's Avatar
Car: 1991 z28
Engine: 5.7L
I have a 91 z28 tpi. Originally it was a 305 but i swapped it with a 350 when I blew the engine. I kept my original fuel injectors from the 305 and had a chip made that allowed me to do so.
My car has idled terribly since the swap, I brought it into the shop today and I was told I need to replace 4 of my injectors and my fuel pump.
Everything is stock on the car with the exception of the exhaust system.
Im going to replace all 8 injectors, it only makes sense that way, and I figure since im changing them I might as well put in the proper injectors for a 350. However, Im not quite sure wich those are. Ive read on some sites that it should have 22# injectors and on others that i should have 24#. Is that 2# really even going to make a difference? Also, I would need a new chip burned but until then would I be able to drive the car with the 350 injectors even though the computer is going to think they are the 305 injectors?
Also, would I benefit at all from installing a performance fuel pump?
I really have no knowledge on this subject, what kind of injectors and pump should I be looking at? Is there one brand that is better than others or certain brands that I should avoid?
Any suggestions are greatly appreciated...thank you in advance.
Old Sep 12, 2007 | 12:04 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Fuel Injectors & Pump suggestions please
your computer should be fine its either burned as a 305 or as a 350 not as the injector size. I,ve seen 350's running on 19# injectors just fine.
Old Sep 12, 2007 | 09:09 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
A good 350 can not run right with 19# injectors unless the fuel pressure is adjusted up to around 56psi, so you would have to have installed an adjustable fuel pressure regulator (AFPR).
My advice to you is to install 24#/hr Ford Racing injectors (I have used mine for about 10 years now) and get a chip to match.
I do not know if your fuel pump is going bad, but if it is the factory unit, have the TTA fuel pump installed,,, it will give you plenty of fuel.
bryan623
Mar 22, 2021 06:43 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
NBrehm
Aug 25, 2015 11:49 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
