What year is my TPI?
Old Sep 12, 2007 | 09:26 PM
geehumshriber's Avatar
I have a TPI engine sitting in the garage, and I want to know what year of an engine it is so I can buy the appropriate year of thirdgen to swap 'er in. She still only has about 90,000 clicks on 'er, and I'd hate to see her sit here for longer. Anyone tell me where I can find out the year for this engine?
Old Sep 13, 2007 | 01:02 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: What year is my TPI?
Can you post a picture of it?
Does it have perimeter bolt valve covers (85-86) or centerbolt valve covers (87-92)?
Does it have a tube going to a 9th injector on the driver's side? (85-88)
Is there a small black retangular MAP sensor on the passenger side of the plenum? (90-92)
Old Sep 13, 2007 | 08:21 PM
They're centerbolt. It's a 305 TPI as well. Didn't they switch to 350 in... 89? Our initial guess was 87, as it came out of an either 87 or 88 Camaro.
Old Sep 13, 2007 | 11:56 PM
Kevin91Z's Avatar
The first 350 TPI's were offered in 1987.
Old Sep 16, 2007 | 01:18 AM
Did they still run 305's at the same time? This one is definitely a 305 (not big enough to be a 350, judging by exhaust manifolds).
It's either 87 or 88, any distinct differences?
Old Sep 16, 2007 | 01:48 AM
Kurt04's Avatar
From what I can tell in my "Chevy TPI Fuel Injection Swappers's Guide" there was no differnce between '87 and '88. And yes they still had 305 as well, I had an '87 305.
Old Sep 16, 2007 | 12:14 PM
Kevin91Z's Avatar
GM used 305's in thirdgens from 82 to 92, all years. There should be a place on the back driver's side corner where it will say "5.0L" or "5.7L" to tell you the engine size.
87 and 88 engines were identical externally.
LT1Formula
20
Nov 14, 2015 12:02 AM
69 Six Pack
Oct 5, 2015 07:51 PM
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
