I have no spark! Help plz
Old Sep 30, 2007 | 07:03 AM
ChampionN84's Avatar
Car: 91 Camaro Z28
I currently am not getting any spark!
Setup Stock 305 MAF TPI that is in a 91tbi car
cranks over but no spark to plugs!
MSD Distribuor and coil
Msd 8m wires
Tested battery 12v
Coil tested good 12v
batt wire going to distributor 12v
ignition module tested good!
Any ideas i am at a loss?
Old Sep 30, 2007 | 10:57 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: I have no spark! Help plz
1) Does your tach wiggle a bit when you are cranking engine???
If no check dizzy pickup coil those do go bad , do a search with my screen name.
If yes proceed to step 2
2) Get a spark plug tester - connect it to the HV output from the coil. Crank - do you get spark?
If Yes check dizzy hat center contact, rotor.
If no remove coil verify HV windings continuity.
Report your findings
//RF
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
