still shakes after balance
Old Oct 1, 2007 | 05:51 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
i have a 383 ,when i put it together i used the stock harmonic balancer and flexplate and it shook bad.i got it balanced and the guy said i needed a 400 balancer but nothing about the flexplate, i put it back together and shakes a bit in idle, not smooth like the factory motor, is also 10.5 to 1 comp ratio and i have poly mounts on engine and trans. any comments
Old Oct 1, 2007 | 06:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: still shakes after balance
If you needed a 400 balancer, you probably should have needed a 400 flexplate as well, unless your engine is some kind of perverse creation.
Old Oct 1, 2007 | 08:13 PM
demon138's Avatar
he builds lot of engines, and he balanced the set with this plate. will it be unbalanced with the new plate?
Old Oct 1, 2007 | 08:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those are questions that only he can answer.
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
monte87cortez
Sep 26, 2015 08:10 PM
88rscamar0
Sep 23, 2015 09:08 PM
Magman
Sep 13, 2015 12:14 AM
