quick? synthetic, what weight?
Old Oct 10, 2007 | 03:31 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
going to be doing an oil change this weekend, going to be using either mobile 1 or rp.. which weight should i go with?
Old Oct 10, 2007 | 06:32 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: quick? synthetic, what weight?
i use the mobil 1 high mileage 10W-40 and no complaints. i wouldn't use anything lighter than 10W-30....SBC's don't like 5W-30 very much. i'd stick with mobil 1 unless you plan to go racing.
Old Oct 10, 2007 | 06:36 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Use the same weight thats already in there. Ive heard 10w-30 gets slightly better fuel mileage,but i dont know if thats true or not.
Old Oct 10, 2007 | 07:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Lighter weights do tend to reduce pumping loses a little. Many OEMs are going with 5W-20 these days.
Old Oct 10, 2007 | 10:46 PM
i used to use 10W-30 but i haven't noticed any drop in fuel economy whatsoever. i think it has to do more with how you drive over how light of an oil you use. i only use the 10W-30 because it provides a little more protection to an engine with almost 130,000 miles and it tends to leak less.
Old Oct 10, 2007 | 10:52 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
my dad's 5.3 (1999, the bad year most blew up) uses full synthetic 5W-20 and it has 169,000 miles on it with no probs. It works great you don't have to change it as much.
Royal purple is over rated. use Valvoline or Mobil 1. They work great, also get a good filter 8 microns or smaller filtration and it will run for a long long time (family vibe has 180,000 miles on it runs great)
F-body-fan
Jan 12, 2023 01:49 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
Damon
Sep 26, 2015 04:29 PM
