2 easy timing questions
Old Oct 20, 2007 | 04:43 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
I got tweo stupid questions but i cant seem to find the answers. First im trying to turn the engine over a bit to get it at tdc on #1 so the damper timing mark will line up with the timing mark on the front oil cover behind the water pum,p. question # 1, how cna i turn the enigne over buy hand, i tried a big wrench on the bolt that hold the damper down but no luck. and also theres like 5 notches on the oil cover timing thingy(technical term) what one is 0 degree timing? Trying to set my base timing on this motor and maybe start it up tormrmow thanks guys!!
Old Oct 20, 2007 | 05:58 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 2 easy timing questions
You may have to take the plugs out to turn if over from the crank bolt. You can "bump" it with the starter to get it close. The deepest V is TDC. About 3/4 of the way down.
Old Oct 20, 2007 | 08:44 PM
Damon's Avatar
Yep, bottom of the "Big V" on the tab is 0* (TDC).
An easy way to turn the engine over is to leave the belt on and turn the engine over by the big nut in the middle of the alternator pulley. That pulley is 4 or 5 times smaller than the crank pulley which means you're getting 4X-5X the leverage on it versus trying to turn the crank pulley directly. You will need to hold some extra tension on the belt, however, to keep the belt from slipping while you do this.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
