Oil Cooler on New 880 Block
Old Oct 21, 2007 | 07:01 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Just got my new Block back from rebuild. I was putting components on and decided to put the oil pump on. Since the block was upside down, I decided to put the OEM oil cooler on the block. Big problem. On the existing block the oil cooler just screwed into the block. On the new block, there is no threads to screw in anything let alone an oil filter. I mean you can see where everthing is supposed to go, but no way for any mating parts to go togethor.. Any help would be greatly appreciated.
Old Oct 21, 2007 | 07:20 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Oil Cooler on New 880 Block
You need to transfer over you oil filter adapter piece from the old block to the new block. It is held on by two small bolts and has a gasket in between the adapter and the block.
Old Oct 22, 2007 | 06:13 AM
ibmtech's Avatar
Car: 1987 IROC-Z
Yeah, I was already thinking that I screwed up. The old block was sold almost 1 month ago. I did forget to take a couple of items off.. The rear main seal housing, but I had access to another. Then then oil filter housing problem. I have one more problem that I am curious about. I bought a new set of AFR 210 75cc heads. These are running dual valve springs. The original rocker studs are alot thicker than what I have. Can I safely use my ARP 7/16 studs with Roller Rockers? I might have to ultimately have to get a larger set of roller rockers.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
carattini
Sep 10, 2015 07:46 AM
apie2546
Sep 5, 2015 07:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
