Stock fuel pump wiring sufficient for A1000?
Old Oct 25, 2007 | 08:03 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Pretty much just said it, but I do have a summit fuel pump relay kit. Just dont feel like installing it. I'd rather use it for something else. The wires with the kit are a little bigger. Can I use the stock wires that run with the tank sender? It would really speed up the process of getting this blower on by monday......
Old Oct 27, 2007 | 03:54 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: Stock fuel pump wiring sufficient for A1000?
ttt
Old Oct 28, 2007 | 10:09 AM
ljnowell's Avatar
it depends. You need to find out the expected amperage draw of the pump. This should be provided somewhere. A stock style fuel pump pumping at 4o-50 psi should be from 5(low) to 8(high). If this puimp is going to draw more than that, you should consider upgrading the wiring.
Old Oct 28, 2007 | 05:15 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I cant find anything, but it advertises flow at 12.5 volts. Whats the worst that could happen? Blowing a fuse?
Old Oct 28, 2007 | 08:16 PM
ljnowell's Avatar
Electrical theory would say that you would blow a fuse. In practical reality, its possible that the amp draw would come right up to the point of the fuse capability and then overheat the wiring. From there its all up in smoke. Not exactly likely but entirely possible. Another thing to consider is, do you want to do this twice?
Old Oct 28, 2007 | 10:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
no reason not to install it properly and run proper guage wires and a relay.
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
