Hesitation and fluctuating idle when warm
Old Oct 26, 2007 | 02:34 PM
butthead09's Avatar
Hi,
I have a 1989 camaro rs 305 TBI 5 speed. When the engine reaches operating temp the idle fluctuates from about 600 to 1000rpm. Also, after it's warm when I take off from a stand still the car hesitates. When cold and running down the street it runs fine. I have replaced the O2, IAC, and knock sensor, cap, rotor, and wires. Any ideas??
Thank you,
Bill
Old Oct 27, 2007 | 11:38 AM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Re: Hesitation and fluctuating idle when warm
check the idle air bleed(AIB) and the EGR circuit
Old Oct 29, 2007 | 11:36 AM
butthead09's Avatar
thanks for the advice. I bypassed the EGR and plugged the vacuum line. The car ran good no problems even after warm. I checked the EGR valve with a vacuum pump and it seems to be working fine. Is there a problem running the car with the EGR disabled? Is something wrong with the EGR even though it check out ok with the vacuum pump? Or is there anything else to look into?
Thanks,
Bill
92firebirdguy
Sep 1, 2016 07:53 AM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
amcnellis
Sep 16, 2015 04:16 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
