4th gen fuel tank
Old Oct 29, 2007 | 07:13 PM
irocz2889's Avatar
Car: 89 iroc z
Engine: tpi
4th gen fuel tank
i was wondering how hard is it to swap a 4th gen tank into my car the tank ill get will most likely be from a 6 cyl is it worth the effort ive already dropped the tank once also do the 4th gen tanks have baffles like the 1LE
Old Nov 2, 2007 | 08:30 PM
irocz2889's Avatar
Car: 89 iroc z
Engine: tpi
Re: 4th gen fuel tank
bump
Old Nov 3, 2007 | 10:52 PM
Rage13's Avatar
Car: 89 Firebird
do a search, there have been a good number of posts about it. 4th gen tank will fit (its been done by a member here), they don't have a baffle but there is a cup in the tank that does the same job, pump always keeps the cup full and pulls fuel from it when the pick up no longer has fuel. theres a thread about that too, with pics if you care to see. hope that helped ya some
Old Nov 4, 2007 | 06:23 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
98+ sending units use a different ohm scale than the third gens & early 4th gens, 82-97 are 0-90 ohm...98`s are 40-250....I`d start with an LT1 tank if it`s baffled like the 98+ ones
Old Nov 11, 2007 | 05:37 AM
irocz2889's Avatar
Car: 89 iroc z
Engine: tpi
so will i be able to just swap the tank right over and still use the same pump and all the fittings so long as its pre 98 even though it might be a 6 cyl
Old Nov 11, 2007 | 09:13 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Something tells me the fittings aren't the same. They certainly are different for the plastic tanks.
What's your motivation for doing this?
Old Nov 23, 2007 | 09:46 PM
irocz2889's Avatar
Car: 89 iroc z
Engine: tpi
my filler neck came loose on mine and if it wasnt too hard i figured it would be an upgrade
Frozer!!!
Jan 19, 2024 04:55 PM
mustangman65_79
Apr 14, 2017 05:37 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
