91 z28 starting question
Old Oct 29, 2007 | 08:57 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
not sure this goes here but here it is....I have a 91 z28 w/a 5.0 and the 4 prong wire that goes to the ignition mod. under dist. cap has no voltage to it any ideas??............I think thats what is keeping me from getting my car started and stay running...also this has what I have gotten it narrowed down to
thanks,,steve
Old Nov 4, 2007 | 04:42 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: 91 z28 starting question
check your fuses if good check for power with the key switch all the way forward as if u were cranking the car.if you dont have power check your wire at the fuse box I had one do the same thing and the wire was loose at the fuse box.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
pfsteichen
Feb 9, 2016 06:59 PM
redmaroz
Aug 16, 2015 11:40 PM
