92 Camaro RS TBI Stalling (Maybe TCC) Help!!
Subscribe
Nov 12, 2007 | 05:41 PM
Info on vehicle first.
1992 Camaro RS
5.0 305
Automatic
Ok their are plenty other threads simliler to this one but I don't think that their symptoms are the same as mine. While driving at any speed and comming to a stop or just slowing down just a little bit the motor will start to stall/die. Some of the time if I catch it in time I can throw it in a lower gear while patting the excelerator and the motor will come back to life. 99% of the time their is nothing I can do to keep it alive. The operating temp seems not to matter. I would think that if it was the TCC that if you put it neutral the motor would stay running, but this is not so. I did the brake test to see if the rpms go up when you tap the brake at speed and from what I can tell the rpms to jump up a little..
Any help would be great.
Reply 0
Nov 12, 2007 | 11:33 PM
Re: 92 Camaro RS TBI Stalling (Maybe TCC) Help!!
check for vaccum leaks and your brake booster
Reply 0
Subscribe
