What style piston is this?
Old Nov 14, 2007 | 09:49 PM
afida15's Avatar
what kind of piston is this? i know its a 350 piston but im just wondering what style
Old Nov 14, 2007 | 09:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What style piston is this?
Dished, with valve reliefs.
Old Nov 14, 2007 | 09:57 PM
afida15's Avatar
alright thank you. i have another question. what kind of heads can i use with these pistons and run pump gas? like a cheap set of vortecs or something. just for a mildly stock 350?
Old Nov 14, 2007 | 10:25 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
with dish pistons and valve reliefs you can run almost any head and run pump gas... vortecs are a good choice for any street motor. make sure to get head gaskets that will allow for .035-.045 quench area. im running a set of 305 vortecs on my 355 with valve relief pistons on pump gas and its running fine... thats a 58cc set of heads not sure what the cr is just havent had time to test it since the build...
Old Nov 14, 2007 | 10:35 PM
afida15's Avatar
alright. thanks for your help. im sure these pistons arent to perfomance orriented lol. i bought a 350 engine rebuild kit off ebay so i could just find a old motor and rebuild it and then after that il save and try to build a better more performance motor.
LT1Formula
Oct 8, 2015 08:34 PM
bschmale66853
Sep 30, 2015 08:11 PM
