under the hood clean-up
Car: 92 camaro rs
Engine: 383 stroker (518 hp)
hey guys, i bought a 92 camaro rs last week and i would like to tear out the stock engine and drivetrain, which is the 3.1 set-up, and be able to take it to the dragstrip and do a little racing rather than watching. could u give me a little insight as to how much of this clutter under the hood i can get rid of and still have a functional car, meaning the headlights, brake lights, etc still work.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: under the hood clean-up
The ECM harness comes from the passenger side bulkhead, and the light and sensor harness comes from the drivers side connector, right under the relays. The two intermingle in the same wiring loom but are mostly seperate. You can cut the loom away and seperate them.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I'm a little confused what are you trying to accomplish? Are you doing and engine and trans swap and wondering what you need to keep?
I took it as he was going to put a computer less carburated monster in there and wanted to eliminate all the unneccesary engine controls...
yeah thats along the lines I was thinking, but it's not very clear at all what hes going for in his post, the way it reads is that he wants to remove the drivetrain, other unnessicary things, then take it to the track and push his way to victory, which I'm assuming isn't the case..
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
