Tuning issue or too big injectors?
Old Dec 11, 2007 | 01:42 PM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Hi,
I take some winaldl logs at idle(750rpm) last saturday and noticed that injector pulse width(bpw) was only 1.2-1.3ms,and integrator was from 92 to 102.BLM was 108.
At first logs intergator was at 85(fuel pressure was 43psi)After that I lower fuelpressure to 37psi,and then I got INT 92-102.Engine have 30lbs FMS injectors.Are those injector rated to 30lbs at 39 or 43 psi?
Engine is sbc 355,vortec heads,stealthram,hotcam,tri-y's no cat etc.Ecm is -870 with lsracingchips tune.
Old Dec 11, 2007 | 02:17 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Tuning issue or too big injectors?
You might post this in the DIY Prom board... they focus more on winaldl logs, readings, etc.
Old Dec 11, 2007 | 02:46 PM
z 28 jari's Avatar
Engine: 385
Ok,I post it there.
Old Dec 11, 2007 | 03:12 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Looks like you are running way rich. You need to lean out the fuel tables.
MustangBeater20
Oct 29, 2022 09:20 PM
Street Lethal
Apr 30, 2019 12:14 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
