Camshaft - Remove Front Nose?
Old Dec 16, 2007 | 01:04 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
On a '91 GTA, will I have to take the nose off the car to pull the cam out? I've never done it in the car before and wanna know what I'm getting myself into lol.
Old Dec 16, 2007 | 01:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Camshaft - Remove Front Nose?
no, you just have to remove the radiator/ac condenser if you have ac. that should give you plenty of room to move the cam out.
i'm about to take mine out here soon and have it stripped to the block. plenty of room to sneak a cam in and out with out the radiator in there. Dont have to remove the front nose
Old Dec 16, 2007 | 02:26 PM
deadtrend1's Avatar
yeup, don't need to remove the nose at all. I keep thinking one of the braces in front of the ac condenser got in the way for some reason. Its been awhile since I needed to pull a cam out.
Old Dec 16, 2007 | 03:05 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
heres a picture when I removed my cam outta my 305 years ago. Yeah you have to take the rad and AC condensor out but also when I did mine one of the braces you see did get in the way of sliding it straight out...I had to unbolt one of the braces but I cant remember which one. ..Screw some really long bolts on the end of the cam to kinda make a handle to ease the removal unless you got a cam removal handle.
Old Dec 16, 2007 | 03:21 PM
deadtrend1's Avatar
yea, I knew one of the braces created a dilema
Old Dec 16, 2007 | 03:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
dang lol i'm gonna have to check mine now
Old Dec 16, 2007 | 04:21 PM
Shift06's Avatar
Thanks guys.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Jake_92RS
Aug 17, 2015 09:42 AM
3rdgenparts
Aug 8, 2015 07:09 PM
