Gas tank question for an 86 camaro
Old Jan 3, 2008 | 05:35 PM
KrazyKaycee's Avatar
Back when I was cleaning out the gas tank from rust and replacing the fuel pump and sending unit I noticed a plastic object that had a rubber line running to it from the gas tank and it was mounted just inside the left rear tire well. It looked like a vent or something but wasnt sure and there is hardly anything left of it other than the plastic that goes into the hose line.
Does anybody know what that is and if there is a replacement part number to get one to replace it if its needed ?
kaycee
Old Jan 3, 2008 | 06:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's a pressure relief valve. You should be able to find the p/n by searching.
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
