Stock cam question for '91 Z28.
Old Jan 4, 2008 | 07:51 PM
Edward01's Avatar
I'm considering a TPI to carb swap and am wondering if the stock roller cam has a cam lobe to operate a mechanical fuel pump?
Thanks,
Ed
Old Jan 5, 2008 | 01:29 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Stock cam question for '91 Z28.
why not just get a 3 port return style regulator and save yourself the headache of pulling the pump out of the tank?
Old Jan 5, 2008 | 01:55 PM
Pat Hall's Avatar
I'm not 100% certain, but probably 99% sure it does have the fuel pump lobe. I don't think they did away with the mech. pump lobe until the LT1 motors.
Old Jan 7, 2008 | 09:24 AM
Edward01's Avatar
89RsPower! & Pat Hall,
Thanks for the response. 89jRsPower!, I pulled this motor out of my '91 Z28 to make room for something else. The Z's motor is going into my '55 Chevy and I didn't want to have to buy a fuel injection tank and pump. I may have to rethink this escapade.
Thanks,
Ed
Old Jan 7, 2008 | 02:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I know the '87 TPI cam I had did have the pump lobe.
When the engine's out, pull the pump cover and stick a pump rod up there, turn the engine over a couple of revolutions. If the rod stays in the same place, you don't have a lobe and you're putting an electric pump in your '55 anyway.
Old Jan 7, 2008 | 08:58 PM
89RsPower!'s Avatar
the solutions pretty simple really, do what 57 described above, it'll cost you all of 5 minutes.. most likely it does have a pump lobe, if not you could always run an inline electric pump.
Old Jan 8, 2008 | 08:07 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I sold a 91 Z28 350 TPI longblock to a guy who installed it a mid-70s El Camino, he called later and asked me the same question. He called later and said it did not have the lobe and had to run a electric fuel pump. Thats what he said anyways.
Old Jan 8, 2008 | 08:15 PM
Damon's Avatar
My 92 RS motor (305 TBI) definitely did NOT have a pump eccentric lobe. Every 87 motor I've taken apart (TPI or TBI) DID have one, however.
I think sometime around 1990 GM started removing the pump eccentric lobe from production line passenger car cams. No prooof, but that seems to be about where things start to get a little funky.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
