which is better?
Old Jan 4, 2008 | 10:30 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
which is better?
so im building a 350 that will get some mods added to it later down the road, and i was just wondering which is better, timing gears or timing chain?
Old Jan 4, 2008 | 10:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you're going down the road, chain.
If you're trailered to the track, then maybe, MAYBE gear.
Old Jan 4, 2008 | 10:39 PM
DARKmj16's Avatar
Engine: 305 tbi
Re: which is better?
lol ok chain it is, but ive been told that gears break less often and then can withstand more power and they dont lose there timing then the chain, any truth behind that?
Old Jan 4, 2008 | 10:53 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The gears often times have more backlash in them than the chain. Also the gears soak up HP and transmit harmonics back and forth between the cam and crank. A good double roller chain won't stretch or break.
Old Jan 4, 2008 | 10:56 PM
DARKmj16's Avatar
Engine: 305 tbi
ok thank you
