difference between internal and external balance
Old Jan 7, 2008 | 08:06 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
what is the difference between internal and external balance? which one is better? what do i need to know about this before i start building my motor.
Old Jan 7, 2008 | 08:13 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
Re: difference between internal and external balance
externally balance is done by the flywheel and harmonic balancer weighting. if it's a 350 you are building it is probably internal as most are. i think 400sbc's are mostly external...ie you could use same balancer on a 305,350 but not on a 400
Old Jan 7, 2008 | 08:16 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
so the 1989 L98 that i took apart is exteranlly. even though im gonna stroke it?
Old Jan 7, 2008 | 09:11 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The L98 you took apart is internally balanced - the harmonic damper is "neutral" balanced. The weight on the flexplate/flywheel is only there to take the place of the counterweight that used to be part of the crank on two-piece rear main seal engines (including 400's) outside of the rear main bearing. All '86-up SBC's are one piece rear main seal, internally balanced, and require a weight on the flexplate/flywheel. All 350 & smaller SBC's use a neutral-balance damper.
The factory 400's were externally balanced because there wasn't enough room inside the crankcase to properly balance the longer 3.75" stroke without using expensive, high-density metal in the counterweights.
Whether you will have an internally or externally balanced 383 depends entirely on the crankshaft you get. Many one-piece rear main seal 3.75" stroke cranks are now internal balance - you need to specify when you choose.
Old Jan 7, 2008 | 11:01 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
thanks for clearing that up with me. i was confused about that for a lil while.
BAMiller
Sep 14, 2015 06:38 PM
fasteddi
Sep 10, 2015 09:32 AM
IROCtometal
Sep 9, 2015 10:01 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
greenyone
Sep 2, 2015 03:39 PM
