0 psi on Fuel gauge, but the car runs
Old Jan 10, 2008 | 09:30 AM
offsetfactor's Avatar
Car: 89 Camaro RS
Transmission: Turbo 350
I installed an afpr after doing a tbi to carb swap. the carb was overflowing with fuel so i set the afpr all the way out, and now it will somewhat idle. I hooked up a fuel gauge on one of the out ports of the fpr but it reads 0 psi even when the car is running
am i using the wrong port, or is the gauge just no good.?
Old Jan 10, 2008 | 12:41 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 0 psi on Fuel gauge, but the car runs
I'd guess it just doesn't read that low. Try it on something else (like a low tire).
Old Jan 10, 2008 | 08:22 PM
Car: 89 Camaro RS
i said its reading 0, thats low enough i think
its a mr gasket fuel gauge, reads from 0-15psi
the gauge is good i tried it on something else, but why would it not read anything hooked to the fpr?
i got a new carb im going to put on but i want to make sure its safe to put on, and not getting too much pressure. but i cant do that when the gauge isnt working... am i safe to hook it up as long as the regulator is installed? its backed all of the way out
Old Jan 10, 2008 | 08:37 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
are you reading pressure *after* the FPR?
Old Jan 10, 2008 | 08:47 PM
Car: 89 Camaro RS
its a mallory 4309 4-port afpr. i just screwed the gauge into one of the ports, should i plug it back up and run the gauge inline at the carb?
Old Jan 10, 2008 | 08:55 PM
Toehead's Avatar
You need to somehow read pressure before the FPR. after the regulator is just return pressure, which is theoretically zero.
Old Jan 10, 2008 | 09:06 PM
Car: 89 Camaro RS
but its a tbi fuel pump, would it not be 20psi before the regulator? i need to get it down to 4-5 to run a carb....
should i not run it on the line feeding the carb instead?? or is the fuel before the fpr adjusted somehow???
Ghettobird52
Jul 5, 2024 11:18 PM
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Kaweh
Aug 9, 2015 02:54 PM
