need some help on 383
Old Jan 10, 2008 | 03:56 PM
MR83ta's Avatar
Car: '83 T/A 2003 Grand Am Gt (built)
Axle/Gears: 3.73 posi
So im building my 383 stroker right now, the motor is at the shop. Im planning on running a supercharger and a little nos. Whats kind of compression ratio should i shoot for, also any suggestions on parts.
Old Jan 11, 2008 | 05:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: need some help on 383
Shoot for compression in the 8's and get forged internals.
Old Jan 16, 2008 | 12:35 AM
MR83ta's Avatar
the way its looking now is 8.1-1 compression, all forged internal from eagle what kind of heads do you think would be a good match for a weiand 871 blower
Old Jan 16, 2008 | 12:49 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
AFR heads are always a good choice, or dart, brodix, etc etc.
Old Jan 16, 2008 | 09:01 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
8.1 might be a little sluggish, but will allow you to run a lot of boost on pump gas. I agree with the AFR's. some 195 eliminators or 210's would be good for your combo
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
