Injector harness in order?
Old Jan 16, 2008 | 05:10 PM
SharpZ28's Avatar
Car: 92 Z28 Camaro
Engine: 350 TPI : Supercharged
Transmission: TH700R4
I just did an engine swap and may have crossed injector clips from the way they were originally, on my 1992 Z28. I see no number on the injector clips and was wondering do they go in a specific firing order, or does the computer handle this? The engines runs, but it is a somewhat radical 406 small block that needs a prom re-calibration, so it is not running correctly with the stock chip. Thanks for any info.
Old Jan 16, 2008 | 05:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Injector harness in order?
It doesn't matter, the injectors are batch-fired.
Old Jan 16, 2008 | 08:38 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
A little clarification: The right bank is all fired together as is the left one. It's OK to mix them up on the same side.
Street Lethal
Apr 30, 2019 12:14 PM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
xxx3man`
Aug 28, 2015 02:21 PM
Keith5
Aug 27, 2015 04:37 PM
