cts code 15 experts
Old Jan 20, 2008 | 12:28 AM
rs4dillon's Avatar
cts code 15 experts
Searched for code 15 help and tried these.
New coolant temp sensor
Checked ohms on both old and new and are within range
At the wire connector I get 5 volts jumping the two pins
Same if ground to block
throws code right away
reset code and car barely starts, very rich
jump connector and I get a 14 and a 15 code says bad connector
What am i missing here ?
89 rs lo3
please help
Old Jan 20, 2008 | 10:25 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: cts code 15 experts
89 rs lo3
please help
At one time, the CTS had a failure mode that would allow coolant to wick up the wiring harness, to the ECM, and cause the contacts to corrode, hence, no signal (on the ground) and the ECM gets pissy, giving the "permanent" code..... check the connector at the ecm, don't remember which one it was.... and see if that is the case. If nothing else, once you find out which wires are the ones you want, test for continuity, and see what ya get.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
djmarch
Oct 2, 2015 10:41 PM
Luigytico09
Oct 1, 2015 08:46 AM
